1 - 2 of 2 Posts
I did a clutch in an '07 c70 and it also needs CV boots. From searching, it appears that one uses a brass hammer to knock the outer joint off the shaft, hitting on the part that rides on the splines. I've given this one a few whacks, but it doesn't seem to want to come off. I belive there is a clip holding it on perhaps? From the search, one just has to hit it hard enough to get the clip to ride up and out of its groove. Is this correct? I sure don't want to break anything.
Thanks!
Check the S40/v50 stickies for a write up. There is a small clip. It'll take a few whacks.
I'd suggest removing the bearings first.
1 - 2 of 2 Posts
