I Just bought a 2007 XC70 with 192000 miles on it. It was an estate sale so do not have a great history. I have a few problems and I just realized Volvo’s are not easy to diagnose or cheap to repair.
problem: when i start the car I get a message DSTC spin control off along with anti-skid temporarily off. As soon as I turn the steering wheel I get anti-skid service required. During this I do have the traction control on right of dash on and the triangle ! Both in orange. Along with this problem I noticed that the car seems to crank quite a bit more than usual to start. Last night I had a complete no start. The car would crank normally but just not start. It did smell of fuel and I did check the shrader valve on the fuel rail ( there was very little pressure just a small squirt) . I nearly killed the battery so I left it for the night and this morning with battery on trickle charge I tried to start it again. I turned the key one time and checked the pressure at the fuel line and it was just a tine drop of fuel. I then turned the key on and off 4 times giving the hum sound under the hood by the headlight time to cycle and tried to start it. It took quite a bit of cranks but it did start. I then proceeded to check the obd2 port with my reader and I could see that live scanning showed 45 psi fuel pressure while the car was running. So far all day every time I turn off the car it restarts.
The big issue here is I only have 1 volvo dealer and he wants to bend me over big to find the issue. Any help would be awesome.
I did remove the clock spring, turned it to check the condition and it actually from center turnes 3-3 1/2 to the left and 3 3/4 to right from center. Seems that the ribbon is stretched. not sure if that helps. Put it all back together and nothing has changed
Oh I did scan for codes with my obd2 code reader and I have none. That this reader is able to read. I do not have the vida reader. I load tested the battery and I am showing 600 cca on a 5 year old 750cca battery.
