1 - 2 of 2 Posts
It began with me changing the lower control arms, ball joints, front struts, front sway bars, rear sway bars and rear struts. All at the same period on my 2004 Volvo S60 2.5 T. I used Karlyn control arms and Karlyn ball joints, and used Meyle struts and sway bars. All parts were purchased from FCP Euro. After weeks of painfully changing all the parts including changing the axels, I decided to take the car for alignment. The technicians at the alignment shop told me that they couldn’t align my car because the toe on the front passenger side is way out and they couldn’t bring it in, they said the inner tie rod will not spin further to bring the toe in. They then suggested that I change my inner tie rod and bring it back for alignment. I took my car home and order a new TRW inner tie rod to replace the existing one and half year old Meyle tie rod on the car.
After the replacement I took the car back for alignment, same problem as before, cannot do the alignment because toe on the front right is way out. I took the car to another shop, same problem, the car will not align. Now I don’t know what to do. I cannot drive the car. Any help is appreciated.
Did you double check and make sure that all the work you did was up to snuff? I know you changed a bunch of things and tracking down what the issue is may be a lot of trial and error but that would be my first suggestion.
Go over EVERYTHING! Especially the control arms and struts.
Also, did they say anything else about your alignment check? Such as any of your other angles?
Sent from my HTC One_M8 using Tapatalk
1 - 2 of 2 Posts
