Getting a set of Heicos volution (ET43)V soon. Can I get away with 10mm spacers up front? Or 12 maybe?
Thanks
I don't see why not. The ET43 is the same on the 17" Pegs. Plus I have seen members run 10mm spacers up front and 15mm in the rear.
Thanks
You will need 10 mm spacers to clear the calipers. The R-specific Heico wheels are et 28 offset to sit flush, so you may want to run 12-15 mm spacers in the front for aesthetics, but you'll be able to get away with 10mm spacers in the front.
Personally, if I was going to run the et 43 Heico wheels, I would run 10mm in the front and 15 mm in the rear.
The cheapest site that I've found for spacers is http:www.novustech.ca
Cheers,
Jeff
Anybody have specs on the bolts? Appropriate pitch and length.?Whos got the best pricing? Thank you.
I use H&R 15mm with mine front & back, no issues & plus gives you a slightly wider track. These are available from IPD, as are the longer lugs that are required.
