I get a popping sound in the dash when ever I first start warming the car up in the morning. It only happens when the heat is on , I suspect it is something explanding in the heating system. I can hold the speaker grille down and it mostly stops the popping but still it is in front of the instrument panel.<p>I have had it to the dealer at least twice and still have the problem. I did not notice it until , I had the car stop on me and they had to replace part of the electronic/ computer system or something(?). I think they had the part of the dash out when they worked on it.<p>Any thoughts.<p>ron
The speaker grill sits on the dash using 'clips' along the edges but does not actually touch anything below it. Below the grill is the bracket/basket that holds the center speaker - if you have that option - that bracket is held down by 5 screws. Below that are two oval pipes that bring the air up to the dash vents, but even if you were able to push down on the bracket/basket, it is far away from the pipes that they would not touch.
Re: (Pinstripe)
thks, I will mention this to the dealer.<p>
