My passenger side headlight has multiple cracks in the glass. Does the 01 v70 share the same headlight assembly with the other models such as the xc70 and "S" series?
Re: Headlights interchangeable between different models/yrs? (snowdragon3)
Yes until the the '05 MY, the headlights are different at this point and no more wipers, spray nozzles instead.<p>Later,
Re: (snowdragon3)
I *think* that there are software differences between the model-years, and that doing this swap in an '01 is possible but there are some hoops that you need to jump through. (Drilling through a resistor is one of the things that you need to do...)<p>Try doing a search on the subject and see what comes out. Someone did this swap not too long ago and posted their results here.
Re: (shrike71)
The S60, V70 and XC70 share the same headlight assembly from 2001 to 2004, in 2005 they changed the design a little not sure if they still fit though. The S80 are not the same therefore don't bother.<p>As for Xenon it should work fine but will find out for you I'll call my cousin and will get back to you.<p>Hope this helps,<br>
Re: (snowdragon3)
Yes, but you'll need a Vadis update (or some other modification to fool the system) to recognise the bi-xenon setup. <p>volvos60t5x did this (after having a plug-n-play HID kit installed): <A HREF="http://forums.swedespeed.com/zerothread?id=52713" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=52713</A>
