so this morning my headlight washers worked, and this afternoon i was showing someone and they came out, sprayed the lights, and wouldn't go back in, or spray anymore. any ideas? thanks!
Re: headlight washers broken? (dannyman1035)
The nozzel is jammed. If you cant get it to go back in then it will probably will require to be replaced. Water pressure pushes them out and they are supposed to recoil back in by the spring system. Might have a jammed spring or something.
Re: headlight washers broken? (ForceFed Motorsports)
i can push it back in but it won't go back in on it's own, i hope this is something i can fix myself but i somehow doubt it's easy to do. nor do i expect it to be cheap at the dealership...
Modified by dannyman1035 at 7:48 PM 4-19-2009
