Ok, so I found the pinned topic. Basically Im putting in some new 05 lights on my lady's car and didn't realize how much of a bi7ch it was to do anything on P2 cars. Here is what I found<p>1) Buy replacement rivets and a rivet gun ready for step 12!<br>2) Drill out the four plastic rivets inside the wheel well<br>3) Remove the headlight wiper arm<br>4) Carefully pull the (usually black) trim panel out of the bumper<br>5) Now remove the side marker lamp attached to the black trim strip<br>6) Remove the indicator lamp assembly by pushing down on the release arm next to the headlight, and then sliding forwards.<br>7) Remove the two plugs from the lower front area of the bumper<br>8) Remove the bumper retaining bolts<br>9) Slide the bumper forwards<br>10) Reach through the gap and remove the remaining headlamp glass retaining clips<br>11) Remove the upper headlamp glass retaining clips<br>12) Work backwards to refit!<br>Thanks Borehamovi<p>Basically Im just wondering if anyone else has any pointers or things to look out for. Lastly, I was looking for a haynes manual or anything I could find for the 02 S60 awd but found nothing but Vadis to be helpful. Do they even make a manual for the car?
I've got the Vadis thing if that helps?<br>I couldnt get it installed on the desktop but I'll try tonight on the laptop<br>it might have more instructions on how to do it
Re: Headlight revoval, Ive searched but have a few Q's (Boomin850)
<br><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Boomin850</b> »</i></TD></TR><TR><TD CLASS="quote">Ok, so I found the pinned topic. Basically Im putting in some new 05 lights on my lady's car and didn't realize how much of a bi7ch it was to do anything on P2 cars. Here is what I found<br></TD></TR></TABLE><p>Not quite that difficult, if you are changing the whole headlight assemblies:<p>1) Remove the headlight wiper arm<br>2) Losen the bumper retaining bolts in wheel well<br>(Remove the plastic pins above the radiator. If they break, replace with screws)<br>3) Slide the bumper forwards and down a bit<br>4) Reach through the gap and remove the remaining headlamp glass retaining bolts, on the side and on the bottom.<br>5) Remove the upper headlamp glass retaining bolts<br>6) Work backwards to refit!<p>But of course the wiring needs to be redone once the old lights are out.<br>
Re: Headlight revoval, Ive searched but have a few Q's (Mika)
Thanks a bunch looks like it should be pretty easy then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Mika</b> »</i></TD></TR><TR><TD CLASS="quote"><br>(Remove the plastic pins above the radiator. If they break, replace with screws)<br></TD></TR></TABLE><p>No reason to break them, just push down in the middle, then pull straight out! <p><br><A HREF="http://xs.to" TARGET="_blank"><IMG SRC="http://xs104.xs.to/xs104/06326/PICT0001.JPG" BORDER="0"></A><p><A HREF="http://xs.to" TARGET="_blank"><IMG SRC="http://xs104.xs.to/xs104/06326/PICT0017.JPG" BORDER="0"></A>
Re: Headlight revoval, Ive searched but have a few Q's (Dede)
So THAT was the trick <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Yeah lol. They use those all over the car.
