Headlight Leveling Sensor for Bi-Active Xenon Lights
1 reading
14K views 17 replies 4 participants last post by  Outback C70
I removed the left rear wheel today to observe the leveling sensor & its linkage...
I had it jacked up by a frame pad just in front of the left side rear wheel arch, and left the suspension hanging.
My friend put his ear up to the left headlamp as I turned the ignition to ON & moved the lighting switch to point staraight up.
He said he heard a mechanical sound coming from the headlight, so that's good.
Shut everything OFF once more and started poking around for the sensor.
When I saw it, it seems as though its actuating arm is pointing a bit off horizontal to downwards... Not at all pulled sharply down as I expected, not even close to the stop.
Given this condition, I wonder if the arm is pointing much higher than horizontal when the car is supported by the road wheel/tire...
If so, would not the level sensor read the car as dragging its butt on the ground and then compensate by aiming the HIDs waasaaay low so as not to dazzle oncoming drivers?
Since the rear ended accident, apparently the lights have been doing this....
At 25 feet, the cutoff is 24 inches on the light board, 75 feet out in front of the car it looks like the projected light cutoff is merely 2 inches off the road surface.. literally.
I know there is a problem.. I am just not 100% clear as to why...
Perhaps one of you has observed the level sensor / installed one/ etc...
Does mine look odd to you all?
Many thanks
M
There's a calibration procedure in VIDA for setting the level. As REM is the interface to the level sensor and you installed a new REM, I wonder if a calibration might be in order.
#3 · (Edited)
No new parts or calibration has been done in this regard.
Wait a moment…. Are you saying the headlamp leveling calibration goes through the Rear Electronic Module that was just replaced? For sure?
I am ignorant of these procedures and dealing with the body shop that wants no part of it unless OKed by insurance company first.
Thanks I appreciate your insights and detail.
That arm positioning doesn’t seem right to me, you know?
Thank you very much, that confirms….
I still want to know if that sensor actuating arm appears to be positioned correctly, given the suspension is hanging in a fully down position, or does the arm travel in much less of an arc than I am imagining?
Cheers,
M
In addition to the above advice & assistance, I came up with a related thought this morning having to do with the recent Rear Electronic Module replacement and programming.
To address the dashboard DSTC fault messages: "Park Assist Service Required" & "Anti-Skid Service Required ", a new Rear Electronic Control Module 30728512 was installed & programmed to the car.
All seemed well until we drove the car after dark and found the Active Bi-Xenon lights 'pointing to the ground'.
Recently, I have learned on these pages that the 'self leveling' [HID] function can be turned On/Off using Volvo software. Apologies as I do not know the proper terminology...
That said, I wonder if a brand new Rear Electronic Control Module has the HID leveling functionality turned ON or Activated by default?
Or is it OFF and need to be tailored/programmed to each car's functionality?
I have read that if OFF.. these active lights will point to their lowest possible setting by design...
If the latter............................ here we are.
* If possible, I am really keen on seeing a screenshot of this 'functionality activation' if you know what I mean..
I am a visual learner.. and may need to show / prove the reason for the headlamps malfunctioning as they are currently.
Thanks once again,
M
#10 · (Edited)
#12 ·
If the Rear Electronic Control Module 30728512 was installed & programmed to the car by a dealer as noted above, then why would you be buying a reload of the exact same software?? Makes no sense to me, light leveling is a standard function and is not a value added feature. Was calibration ever attempted?
#13 ·
The original REM unit was diagnosed, deemed faulty and a new replacement was installed and the replacement keyed to my car by an outside 3rd party [for the body shop doing the repairs].
This was not a Volvo specialist, nor a dealership doing the work.
I called a dealership earlier today and was told a new REM must have a download REM Reload for the Active Bi-Xenons to work properly.
As far as calibrating the position sensor for the Bi-Xenons, I do not know what was done. Obviously, if not done here we are...
As I was at the body shop today, the company who did the programming said the REM reload HAD already been done.
There was NO Volvo software download listed as a line item on my repair invoices and/or supplements.. At a retail cost of $99. I would expect to see that listed, ergo all my questions....
I know a lot more about B18 & B20 motors, S.U. carburettors, and early EFI.... As you easily see, I don't know VIDA or any of that so I try to gather what makes sense to me & go forwards, you know?
What you say just now makes perfect sense given if the fellow loaded the REM Reload.. then it is likely the Bi-Xenons leveling calibration is unlikely to have been done...
Or there is another fault as well...
I appreciate your posts on this subject. They have helped.
M
Thanks John,
Having discussed this issue with both the insurance Co. & the body shop... I have made an appointment at the body shop for their guy to sort it out once & for all.
He knows what he has done for the REM already, so wouldn't have to start from scratch [as it were].
They & the insurance people appear very keen on getting resolution to this.
I'll know more on Monday afternoon.
M
#17 ·
UPDATE
I picked up the car yesterday afternoon after the Scan folks were done with it.. I was told the fellow re-calibrated the position sensor [again]...
Was told: "If there were still a problem I should go to the dealership & send the insurance Co. the bill.."
Last night, after dark, we went out on a road test....
Headlights are A-OK now, just as they were before the body repairs..
This image from post 4 I included in my emails to insurance company and printed up to give to the body shop.... absolutely saved the day.
By that, I mean the customer, the insurance company, the body shop, and the outside automotive computer service were all on the same page.
This brought clear results so many thanks to all who advised/assisted.
M
#18 ·
My C70 has similar issues, the low beam is way too low. I was looking into the calibration procedure and found that both the front and rear suspension height sensors are both to be between 2 and 4 volts. The car needs to be level too. However my front suspension reads around 1.6 volts. The calibration went ahead with no change to the light angle, so was thinking of altering the voltages by adjustment to trick the lights into thinking they need to come up a bit higher.
