Anyone know where to get the PLASTIC lenses for the 05-09 headlights? I have one that is cracked.
There are no replacement lenses for the 05+ headlights since they're sonic welded and not meant to be removed. In fact it's nearly impossible to remove the lens without breaking it or the housing in some way and simply baking the headlights isn't even sufficient for removing the lens.
Oe headlights are pricey so if you want a new one I'd go aftermarket but keep in mind if you are only purchasing one keep in mind your headlight probably has some wear and hazing and you might be better off going to Erie volvo and sourcing a used one so it matches better.
