1 - 8 of 8 Posts
Hey Everyone..<br>A few days ago my headlight bulb burned out on the passanger side. I replaced the light and it still says bulb failure. I checked all fuses by the driver side door and still no light. I'm not getting any power to the bulb whatsoever as I've checked it with a voltmeter. Are there any other fuses? Anyone have any ideas???
Re: Headlight issues... (N3rd)
Do they work? Or is it just the notice? There are so many bulbs in these cars I would make sure they are all work.
your in hershey ? <p>sweet <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <p><<< union deposit
If im not mistaken, a headlight out will yield a "dipped beam failure" message. If it says something else, i would check your other bulbs.
Re: (Turb04S60)
The dash says... low beam failure.. I've checked all the other bulbs and they're functional... I'm really not sure what the heck is going on with this car.
Re: (N3rd)
I actually had a problem somewhat similar to this recently. One of my fog lights went out...so i went and bought yellow ones from local A&A store...i changed it and it still didnt work. So i took the trusty owners manual and did a bit of reading. Seemed that the fuse was blown. If you didnt know already, there are three main fuse boxes...1)under hood 2) on drivers side where opening of door is(plastic pops off) 3) under the steering wheel there are 2 Star screws. remove them and there is a whole other set of fuses. I would take your owners manual out and check to see if there is a fuse for the lowbeam light. Probably towards the back of the manual ... hope this helps <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
I forgot about the fuse box beneath the bonnet. Diablo, thank you... everything is working perfectly.
Re: (N3rd)
Your welcome... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
1 - 8 of 8 Posts
