I just replaced my bulbs in my headlights with Xenon match bulbs. I had a friend of mine do this on his vehicle with the exact same bulbs and he told me he had to adjust the lights after installing the bulbs. I have researched and have found no information of a way I could adjust the headlights. My low beams don't seem to be adjusted correctly. The drivers side beam seems to be way off. Is there any way of adjusting the headlights? I have the Halogen headlights by the way. Please help. Thanks
Re: HeadLight Adjustment, is it possible with Halogen Headlamps? (appleuzr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>appleuzr</b> »</i></TD></TR><TR><TD CLASS="quote">I just replaced my bulbs in my headlights with Xenon match bulbs. I had a friend of mine do this on his vehicle with the exact same bulbs and he told me he had to adjust the lights after installing the bulbs. I have researched and have found no information of a way I could adjust the headlights. My low beams don't seem to be adjusted correctly. The drivers side beam seems to be way off. Is there any way of adjusting the headlights? I have the Halogen headlights by the way. Please help. Thanks</TD></TR></TABLE><p>Have you tried searching this forum? If you check the archives you should find handy information with photos to guide you...<p>UKMatt
Re: HeadLight Adjustment, is it possible with Halogen Headlamps? (ukmatt)
I have tried searching the forum and it with about 8 different combinations, it continues to say search failed, try again later. If you could direct me to a post that would help me resolve my problem I would appreciate it. I'm kinda new on this thing and appreciate any help I can get. Thanks
ya, search is broken right now.
Have not checked on the low beams, but just adjusted my fog lights over the weekend. For the fogs, take off the panel and there is a philips srew visible. Park in front of a wall or garage door at night and turn the screw to move the light beam up or down. My fogs were miss aligned and one pointed way too low. A few qick turns brought them up to where they should be. Imagine the same adjustment is available for the low beams. Thought I may need an adjustment after installing my hoens but none needed. If I find anything, will pass it along.
