1 - 20 of 23 Posts
My rear headrest release suddenly stopped working. Anyone else have this problem, and how can i get it fixed without going to the dealership
Re: head boppers no workie (S60 t5er)
oh no! that's my favorite feature! best of luck getting it fixed! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
alright, I am a guy.... but I just find "head boppers no workie" cute... please do not ask me if I am gay
Re: head boppers no workie (myVolvoS60T5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>myVolvoS60T5</b> »</i></TD></TR><TR><TD CLASS="quote">alright, I am a guy.... but I just find "head boppers no workie" cute... please do not ask me if I am gay</TD></TR></TABLE><p>"head boppers no workie" is cute funny, not cute homosexual <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
I hardly ever use that button, but I like that it is there <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
When you press the button, do you hear the solenoids activating?<br>If the solenoids do not activate, check the fuse. If the fuse is ok, check the cabling to the solenoids. Ask someone to push the button while you monitor with a multimeter at the solenoids. If it shows 12v, then the solenoids are bad.
Re: head boppers no workie (ig_mb)
thanks for the input, I will try that when the weather lightens up here a bit, quite a bit of rain this weekend. Anyone know which fuse to check, or atleast what compartment? I am assuming it would probably be inside next to the dash.
Re: (exodus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>exodus</b> »</i></TD></TR><TR><TD CLASS="quote">I hardly ever use that button, but I like that it is there <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> </TD></TR></TABLE><p>i use those puppies all the time!<br>as soon as someone gets out of the backseat, those things go right back down!
Re: (phuz)
head boppers work now.... didnt do anything to fix them. Did get a couple subwoofers back there that might have knocked whatever was loose back into place to get them working again tho
Re: (S60 t5er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>S60 t5er</b> »</i></TD></TR><TR><TD CLASS="quote">head boppers work now.... didnt do anything to fix them. Did get a couple subwoofers back there that might have knocked whatever was loose back into place to get them working again tho</TD></TR></TABLE><p>what kind of subs? how was the install???
Re: (darylkaiser31)
Subs are SUPER easy to install in an S60. The battery is already in the trunk, so there are no wires to run at all throughout the car. For the pre-ins just get a hi-level converter, (I find no need to connect to the deck with a cable, as this is only for subs, so you are not really going to hear a difference - if I was going to amp the speakers, definitely use a cable) and connect to rear deck speakers. For the remote wire I just tapped into the DRL circuit...i know i know...but it works, and the amp only comes on when the key is in pos. two, just what I wanted. ( my AWD had a switched 12v source in the rear fuse block, my T5 doesn't so this is what I used)
Re: (deep60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>deep60</b> »</i></TD></TR><TR><TD CLASS="quote">Subs are SUPER easy to install in an S60.</TD></TR></TABLE><p>OK, good to know. I'm probably going to get a powered sub from Crutchfield or Magnolia and do the speaker-level inputs from the trunk. I like the AudioBahn.
use your rear fog light switch <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <p>to turn your amp on and off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: (OSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>OSR</b> »</i></TD></TR><TR><TD CLASS="quote">use your rear fog light switch to turn your amp on and off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> </TD></TR></TABLE><p>Really? That's handy! I'm now actually thinking of just mounting a small 2-channel amp on the underside of the rear deck between the speakers to give them a little more juice. Does anyone know how difficult it would be to swap out the stock rear deck speakers? Please advise.
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>i use those puppies all the time!<br>as soon as someone gets out of the backseat, those things go right back down!</TD></TR></TABLE><p>I use them when someone is sitting in the back seat and they get out of hand. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Discussion Starter · #16 ·
Re: (darylkaiser31)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>darylkaiser31</b> »</i></TD></TR><TR><TD CLASS="quote">what kind of subs? how was the install???</TD></TR></TABLE><p>2 alpine 12" type R's each running off a 600 watt rms alpine mono amp.<br>type r speakers in the doors<br>4 channel alpine amp for door speakers<br>Iva-w200 double din head unit with dvd plus full speed ipod cable.<br>eDead's version of dynamat in trunk and doors<br>plus a optima yellow top in the trunk.<p>As stated previously, fairly easy to install subs in trunk since battery is there. Most vehicles with battery up front you have to pull the power line thru the firewall which can be a pita.<p>I took the remote on from headunit since i was running the RCA cables anyways from the headunit to the amps. Very happy with the system so far. I heard the Alpine type X's are a great choice too.<br>
Re: (S60 t5er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>S60 t5er</b> »</i></TD></TR><TR><TD CLASS="quote"><br>2 alpine 12" type R's each running off a 600 watt rms alpine mono amp.<br>type r speakers in the doors<br>4 channel alpine amp for door speakers<br>Iva-w200 double din head unit with dvd plus full speed ipod cable.<br>eDead's version of dynamat in trunk and doors<br>plus a optima yellow top in the trunk. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <I><B>what's that?</B></I><br></TD></TR></TABLE><p>Very nice! Maybe a bit rich for my blood, but I bet it sounds superb. Personally, I just want to add some power to my system. I'll settle for the stock HU-650 deck, but it just needs more JUICE! I have the Volvo 3-way components in the front door, which are pretty decent. I'm having some Polk db650 put into the rear doors, and am debating about the rear deck. I was thinking it would be pretty slick to install a couple 8" Polk Momo subs in place of the stock 8" coaxial. Anyway, what rating 4-channel do you have for the door speakers and where is it hidden?<BR><BR>
<i>Modified by darylkaiser31 at 11:33 AM 3-18-2007</i>
Discussion Starter · #18 ·
Re: (darylkaiser31)
the 4 channel is model MRP-F450. 140 watts per channel at 2 ohms. 70 watts per channel at 4 ohms. The ratings are continous power (RMS), peak power is much higher. Since i have a sub box in the trunk, all 3 of my amps are mounted on the back of the box out of sight. It might be a good idea to look at mounting it under the back seat cushion if there is enough room there.
Re: (S60 t5er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>S60 t5er</b> »</i></TD></TR><TR><TD CLASS="quote">the 4 channel is model MRP-F450. 140 watts per channel at 2 ohms. 70 watts per channel at 4 ohms. The ratings are continous power (RMS), peak power is much higher. Since i have a sub box in the trunk, all 3 of my amps are mounted on the back of the box out of sight. It might be a good idea to look at mounting it under the back seat cushion if there is enough room there.</TD></TR></TABLE><p>OK, good to know. I attempted to remove the rear seat cushion today, but after my little experiment with the speaker grills, I'll leave well enough alone for the time being. I'm also a bit concerned about heat dissipation, so the underside of the rear deck seems like a decent location as long as the unit isn't too big. I need to keep my trunk space!<p>
Discussion Starter · #20 ·
Re: (darylkaiser31)
should be able to mount it upside down underneath the rear deck. Might be a bit harder to screw it right on to the metal and also connect all the speakers wires while being upside down, but managable.
1 - 20 of 23 Posts
