Hi all,<p>I am having a weird problem with my S60R. (MT)<p>When driving uphill in 2nd gear at moderate speeds, sometimes when I brake, the ABS comes on, the car will hardly brake and even so I depress the clutch, the engine will nearly stall for a second. Like if the clutch did not disengage... but it does.<p>Then... just as quickly as the problem came about, it goes away. Does this only when going uphill.<p>My dealer is aware of it as I showed him the problem, reading the ECU there were no fault codes and he is trying to find out more about the problem.<p>Anyone have any idea what could cause this problem.<p>Thanks for you help!<p>Regards,<br>Coolknight
there were posts about uphill braking issues awhile back.<p><A HREF="http://forums.swedespeed.com/zerothread?id=56032" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=56032</A><p><A HREF="http://forums.swedespeed.com/zerothread?id=43666" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=43666</A><p>hope this helps ya!
Re: Having a clutch or ABS problem, need help. (Coolknight)
Thanks for the information. But an issue without a solution does not help me much... but at least now I know that it is probably a sensor.<p>Regards,<br>Coolknight
