1 - 8 of 8 Posts
Re: Has anyone install AT Oil Cooler on S80T6 (veilsidez)
baring any problems. i should have this exact AT oil cooler installed by next monday!
well, the kit is installed <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> i'll be picking up my car on sunday when i get back into town after vacation. also had my grill, new QuickBrickMotorsports front endlinks, and a ding fixed. nice!
Pics of your grill? please sir <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">Pics of your grill? please sir <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"></TD></TR></TABLE><p>when i get home <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> i didn't mask off the border. but i did get almost 1 full paintbomb of plastidip down on it! too bad i couldn't get a new emblem, i'll have to work on that one next.
ok here's some quick pix of a couple of changes.<p>what you can see of the AT cooler. the bottom radiator section is the AT cooler. the part above that is the existing AC condensor. the AT cooler is a kit from VivaPerformance that is a drop in upgrade for the transmission. no cutting, or drilling required <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"><p><IMG SRC="http://home.comcast.net/~mrnutty1/atcooler.jpg" BORDER="0"><p>here's a picture of the grill i painted up. nearly 1 full can of plasti-dip!<p><IMG SRC="http://home.comcast.net/~mrnutty1/grill.jpg" BORDER="0"><p>and here it is all together (yay!)<p><IMG SRC="http://home.comcast.net/~mrnutty1/front.jpg" BORDER="0"><br><BR><BR>
<i>Modified by SkyWriter at 3:38 PM 8-28-2006</i>
<A HREF="http://www.perma-cool.com/Catalog/Cat_page02.html" TARGET="_blank">http://www.perma-cool.com/Catalog/Cat_page02.html</A><p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote">Automatic transmissions generate large amounts of heat and are totally dependant on the transmission fluid for cooling. When the fluid temperature exceeds 200°F the fluid deteriorates rapidly, diminishing its ability to lubricate and cool critical valves, springs, seals and other internal components, leading to premature failure and costly repairs. Over 90% of all automatic transmission failures are caused by overheating. A 20° drop in fluid temperature can double the life of the transmission! <p> The inefficient factory fluid cooler is located in the radiator's coolant holding tank. The hot trans fluid is cooled by transferring its heat to the colder engine coolant that surrounds it. The minimal temperature difference between the two fluids under normal conditions causes little, if any, drop in the transmission fluid temperature.<p> Perma-Cool® Transmission Oil Coolers perform best when installed in conjunction with the factory cooler and mounted in front of the radiator. With cool fluid re-entering the transmission, the valves, springs and seals perform as intended, resulting in smoother operation, positive shifts, lower floor board temperatures and extended life.<p> If you use your vehicle for towing, drive in stop-and-go traffic, or carry heavy loads, your transmission needs a Perma-Cool® Transmission Oil Cooler. If you drive a recreational vehicle, a street machine with a high-performance automatic transmission, or a race car, you also need a Perma-Cool® Transmission Oil Cooler.</TD></TR></TABLE><p><br>
1 - 8 of 8 Posts
