1 - 9 of 9 Posts
Re: Handle Better? (c70c70c70)
1- Lowering springs (center of gravity will be lower)
2- Swaybars and strutbar
3- Struts and shocks
2002 C70 Coupe
Re: (Token)
Not to hijack the thread, but what is a good tire pressure? I had some issues with that on the autocross at Carlisle...
Re: (Token)
Springs - 1.) TME springs if you can find them, 2.) Eibach-Prokit
Struts - 1.) Coilovers, 2.) Koni Adjustables, 3.) Koni FSD
Sway Bars - 1.) Ipd hands down!
Strut Tower Brace - 1.) OEM volvo
Tires - 1.) Michelin Pilot Sport PS2!
When you're done with this combination, your C70 will be a different beast! It will be the best money you've spend next to an ECU re-flash.
Re: (C70drvr)
Quote, originally posted by C70drvr »
Buy a 3 series!
j/k
Your C70 has clearly not a good roadhandling... (with wrong rear axle and jacked up suspension), otherwise you wouldn't say that.
A C70 with good suspension corners really well (offcourse the long corners, it's not a hot hatch).
Re: (BenES)
Quote, originally posted by BenES »
Way to take a joke
1 - 9 of 9 Posts
