Okay, I know there's at least 3 people who were complaining that their halogens were too low. It was maddening to adjust the screw and find it tap out without moving up enough. Well I figured it out...
The actual height adjustment screw is on the side (closest to the other lamp) of the headlight. There's a small service port to get at it. The only way I could adjust it in the car is with a two 1/4" extensions and a 1/4" -> 6mm hex socket. But this is the right screw, you can get it + 6 feet up or down at 20 feet back.
I'll try to get a picture, but it's pretty far down there. If you take the headlight out you can see it pretty clearly on the side.
The other adjustment is for left-right. It all makes sense now
