Re: (Vash13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Vash13</b> »</i></TD></TR><TR><TD CLASS="quote">Hehehe<br>My Acura RDX has SH AWD which can shift power to any wheel that is needed. </TD></TR></TABLE><p>Let me respectfully correct you. SH-AWD can shift power to the left and right only in the rear. <p>Here's my rant. There are other cars that can send power to the left and right as needed. However, SH-AWD can also transfer engine braking force front and rear and side to side (rear) as needed for stability. Here's what nobody else has- the planetary gear setup on the rear to spin the outside wheel 5% faster in a turn. Why has Acura/Honda not promoted this or its lineage? Starting w/ 4 wheel steering on the Prelude in 1988, and then the Prelude SH in 1997(?). The Prelude SH used this type of planetary gear setup to reduce the inside wheel spinning in turns and was the best handling FWD car made. They just put that "differential" in the rear of the RL/RDX/MDX and gave the 4WS effect. Drive your RDX fast around turns, and you will feel the rear end rotating around which reduces the turning load on the front tires. Absolutely stellar, yet hardly anybody seems to understand that this is the key to the SH part of the AWD.
