Re: H&R Spacer Part Numbers (05s60r)
Quote, originally posted by 05s60r » |
George from vptuning.com will be stocking the 20mm (10mmx2) H&R spacers for the R, it is not on their web site, if you want a set, send an email to:
[email protected]
The longer bolts are 18mm in diameter (stock is 19mm), their website said 17mm
He will get PFC or Hawks pads for those interested.
Billy
19 mm is the diameter of stock bolt head, 17mm is the diameter of the aftermarket bolt heads, 14mm is diameter of the bolt. You need bolts that are at least 43mm long, as stock bolts are 33mm (most likely they will come in 45mm). Also, you need to specify the 60 degree fixed taper head bolt, should be around $2.00 per. Flloating taper head bolts are available (what comes on the car), but at $5.00 per bolt, not sure the floating bit is worth it.
Let me know what VPTuning is selling them for, I can get the 10mm over here pretty reasonable. I was setting up a group buy a few months ago, but Svenske found a distributor, so wasn't a need. However, I can easily do one, still have my contact.
