Wiring harness, Ecu, collar sleeve, cv axles, TCM. I think there's more to it than that. You're better off trading for an 06/07 car.
Moderator
U can buy my '06 trans and whatnot. I plan to do a manual swap
If you buy an 06 GT, make absolutely sure that it's either not one of the faulty valve body units or if it is, have the unit replaced while the transmission is off the caR.
You can't just drop in a 6 speed into a 5 speed car. Doesn't quite work that way. Talk to Lucky from ARD about the actual capabilities of making it work.
