1 - 2 of 2 Posts
Re: Grill removal (retired12)
you have to remove 4 or 5 plastic clips that hold the top of the bumper cover to the frame of the car they are right at the edge. the easiest way I found was to push down the inside of them with a small robertson screwdriver then pull them up and out. you have to push pretty hard sometimes.
now you have to kind of pull the top of the bumper up and you will see the top of the grill. there are 3 more clips like the ones on the bottom work them with a flat head screwdriver and you should be able to release them Then the grill should come out. hope this helps let me know if you have any more questions.
I just did this to install my lights http://********************/smile/emthup.gif
Matt
Modified by Mcally_V70AWD at 1:02 PM 3-15-2006
1 - 2 of 2 Posts
