Upper control (a-arms) AWD. The prototype is together. Any interest?
I have not welded it because I need to dis assemble it for production reasons. It works nicely and has good clearance. Made from 4130 DOM Chrome Moly, 3/4" QA1 poly injected heim joint, OEM fasteners.
I 'll have a firm price on Monday and I'll start taking orders.
Re: Got Camber? (300+_T5R_855)
CJ, Dumb question. Are these adjustable so we can dial in rear camber, or do they take out -ve camber to original spec? I have -1degree rear camber now both sides (probably due to worn Nivos?) and like it. Will this be compatible with your adjustable castor setup (sorry I can't remember what those arms are called)? Appreciate you doing gear for us AWD types!!
Re: Got Camber? (PeterD)
Peter,
That's what these are designed for. When the AWD cars are lowered there is not enough camber adjustment and they chew up tires. This will allow you to fine tune your camber so you don't burn through tires if your car has been lowered. The other part i make is the adjustable toe link which adjusts your toe in or out in the rear.
CJ
Damn...those are some nice control arms...
Wow...nice work!
I have a firm price on these. The package will include:
AWD left and right upper rear a-arm
3/4" QA1 polymer injected heim joint and steel bushing.
Uses existing fasteners and suspension bushings.
Final design will have slightly straighter tubes and will be boxed both top and bottom.
$599.50 per set. Pre pay your order and receive a 10% discount. All prices are plus shipping. Please allow 2 weeks for delivery form the time your order is placed.
Discounts do not apply on credit card or PayPal payments.
