1 - 6 of 6 Posts
Been there ever since I did the ipd intake and boostability kit.. But because the cars been parked for the winter... Didn't think about it...
Thoughts? Is this the bad noise?
https://youtu.be/oXICcdMAzMk
Sent from my Pixel 3 XL using Tapatalk
Bad sound. Sounds like compressor surge. Maybe the diverter isn’t opening when you lift.
I ran into this issue and found that there was a little plug not fully seated and was throwing the caR for a loop.
Sent from my Pixel 3 using Tapatalk
Thanks this is what I thought... I'll play with the tension on the valve...
Thx
Sounds almost like a turbo that the bypass valve isn't working correctly on, sounds basically like a normal turbo car when they dont have a blow off valve, the air surges back against the turbo wheel and causes that fluttering sound. Not usually a bad thing but it is on volvos since they are supposed to recirculate. I'd check the bypass valve
Sent from my SM-G955U using Tapatalk
Ok.. So was totally compressor surge.
I backed out the adjuster on the diverter completely as an a/b test... And it went away.
I'm on the Dyno tomorrow for a baseline test of hp before tuning starts. So I'll watch to see boost and if the diverter is now leaking boost.. And adjust from there.
Thx all
1 - 6 of 6 Posts
