1 - 8 of 8 Posts
Searched this couldn't find anything, What is a good REM source for an amp turn on in the trunk.
Re: Good REM source for trunk amp (assa55in)
Just run a line to the fuse panel in the drivers side dash and tap into the cigarette lighter. Theres fuses in the trunk but im not sure if there are any which go on/off with the ignition.
Re: (firehawk618)
trunk not in the mood to run wires back up front. Looking for something easy to get at that can act as a REM
Re: (Turbos60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Turbos60</b> »</i></TD></TR><TR><TD CLASS="quote">Maybe you could try fuse #10 for the Antenna? There is a fuse panel on the left side of the trunk.<br>Let us know if it works.</TD></TR></TABLE><p>i'm preeeetty sure it stays on.<p>the only way to get a switched source in rear on an -04 is to buy the trailer wiring relay, i believe.<p>*Waits for Puredrive07 to comment*
Re: (shagginwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>shagginwagon</b> »</i></TD></TR><TR><TD CLASS="quote">you could use your rear foglight harness if you wanted a way to turn the amp on and off too...</TD></TR></TABLE><br>Yea but then you would piss the people behind you off when you listen to music <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>Just try them all and see if any are switched off/on with the ignition.
1 - 8 of 8 Posts
