1 - 8 of 8 Posts
Anybody have experience with a "good faith" repair and VCNA? Our car just went off extended warranty (through Volvo) by a couple hundred miles and suddenly a wheel bearing and a headlight issue have popped up? Who do I contact @ Volvo for this?
Sent from my DROIDX using Tapatalk
I guess you meant - good will...
Dealer can charge you for the repairs in good faith...there is nothing inherently bad in paid services...
I will start with the dealer that you have the closest relations with, but I doubt the success...
They actually sometimes refer to these repairs as "good faith" referring to the idea that they are taking it in "good faith" that the problems existed before the warranty ran out.
The dealer is Barry in Newport and they're fine. It probably just dumb luck.
I would try the dealer first. They often will advocate for you with VCNA as they want you to make a return purchase and continue servicing with them.
I would think your chances are better if the problem is a fairly common one. Aren't wheel bearing
failures pretty common on earlier model years (especially the rear)?
1 - 8 of 8 Posts
