Cam seals?
Thought about that. Do I need any special tools for pulling the VVT hubs to do that?Cam seals?
If you find the belt wet with oil then do the seals, otherwise let them be.Thought about that. Do I need any special tools for pulling the VVT hubs to do that?
This is the cam tool I bought. FCP says it’ll work with any 5 cylinder Volvo, which makes sense to me. Should I get a different one instead?If you find the belt wet with oil then do the seals, otherwise let them be.
I used a clamp to hold the sprockets in position, slipped the old belt off and the new one on.
CTA front cam locking tool will NOT fit your engine, its for 1998 and prior years. You can make it work by only engaging 3 of the legs and I've done that too...but its a bit hokey.
You can can't fit much in the front of the engine to clean the water pump surface, certainly not a drill, maybe a tiny die grinder if you have air, I do it by hand. Very low torque on those pump bolts, I recall 12 ft lb, thats no for a big ratchet.
I used a little stubby ratchet and just snugged them up.
Yeh but thats the rear locking tool, more involved just getting it installed and not needed unless you do cam seals.This is the cam tool I bought. FCP says it’ll work with any 5 cylinder Volvo, which makes sense to me. Should I get a different one instead?
Volvo Camshaft Locking Tool - CTA Manufacturing 2864
Volvo Camshaft Locking Tool - CTA Manufacturing 2864www.fcpeuro.com
I'll get the bolts too to be safe.Agreed - no reason to do the cams, unless wet/sweating.
I also replace the WP bolts, although not a necessity.
Ok. I'll get the rear lock tool in case I need to do the seals. If I don't, I can always return it.Yeh but thats the rear locking tool, more involved just getting it installed and not needed unless you do cam seals.
Below is the front sprocket tool but it doesn't really fit, I had one from my old red block days so I made it work but its not worth buying just to cobble it.
Volvo Camshaft Locking Tool Front - CTA Manufacturing 2883
Volvo Camshaft Locking Tool Front - CTA Manufacturing 2883www.fcpeuro.com
Probably better off buying a serpentine wrench .
I'd add chemical gasket remover to the list, I had a very difficult time getting rid of all the old gasket material on the engine side mating surface and recall wishing I had some gasket remover on hand to soften what was still stuck to the engine.Alright, I’m about to hit the service interval for the timing belt in my 04 XC70 so I’m putting an order together on parts I’ll need. So far I have:
Is there anything I’m missing? Any tips to make the job go smoother? Thanks!
- Timing belt (genuine Volvo)
- Tensioner
- Tensioner bolt
- Idler
- Aisin water pump
- Serpentine belt
- Serpentine belt tensioner
- Coolant
- CTA cam lock tool
Will brake cleaner work? I've got so much of that crap laying aroundI'd add chemical gasket remover to the list, I had a very difficult time getting rid of all the old gasket material on the engine side mating surface and recall wishing I had some gasket remover on hand to soften what was still stuck to the engine.
I've read WD40 will soften gaskets but I don't have any experience using it for that purpose.Will brake cleaner work? I've got so much of that crap laying around
Quite often the seals get pushed out by crankcase pressure, if you can inflate a glove over the oil filler, that same pressure is pushing on the seals and they have no retainer to keep them in place.I'll get the bolts too to be safe.
PCV wasn't in great shape when I got the car. Refreshed all of that like 10k miles ago. I'll get the seals in case I need them, and if I don't, I can always return them or add them to my bin of spare partsQuite often the seals get pushed out by crankcase pressure, if you can inflate a glove over the oil filler, that same pressure is pushing on the seals and they have no retainer to keep them in place.
My cam seals leaked at 175k miles, they were not pushed out but still leaking. They probably just wore out.
i installed a turbo gauge to keep an eye on vacuum at a glance.
If the seals are leaking it will be apparent at the bottom of the belt area, the lower belt cover will be dripping oil.
Yeah the cvvt hub is a whole different animal. You will know right away if that’s leaking.At that mileage, if the cam seals are leaking it is often caused by excessive play in the CVVT hub(s). They come off to do the seals so I'd consider replacement. That will add significant cost. I'd also suggest replacing the CVVT hub bolts at that time.
I'm not talking about the hub itself leaking. That usually doesn't happen. But they develop excessive play which causes the cam seal to leak.Yeah the cvvt hub is a whole different animal. You will know right away if that’s leaking.
^This. LolI'm not talking about the hub itself leaking. That usually doesn't happen. But they develop excessive play which causes the cam seal to leak.
