Hey so coudln't find a thread on this anywhere... Excuse me if I missed it.
I am trying to install a QTP cut out which is pretty much coming down to where to draw power and the placement for the switch. I decided a good spot is right next to the front cigarette lighter. I will be able to tuck the switch in there perfectly. I will also have no issues running power back to where I have the cut out (by 2nd resonator.)
My question however is towards someone more "eletrically" minded than myself. I could simply just power the switch and entire cut out by unplugging the cigarette lighter and just using the outlet for the switch. However, this would result in my cigarette lighter not working. What I would like to do is tap into the "-" power on the cigarette lighter and run this to the switch which will be grounded. My questions regarding this are:
1) Will the cigaratte lighter and switch both have enough power at the same time set up this way?
2) I notice two grey wires runing to either "+" or "-", and two black wires running to either "+" or "-" into the cigarette lighter. Once I figure out which one is "-", can I just pull one of those wires and use it for the switch, only leaving one running to the cigarette lighter? Or does the cigareete lighter need those four wires running to it (two to the "+" and two to the "-")... Essentially there seems to be two "-" power wires running into the cigarette lighter, and I am jsut wondering if I can steal one of these for the switch.
Thanks for any help, I do not know much about electricity in general.
If this was unclear, let me know and I will try to be more specific.
