81 - 86 of 86 Posts
Do you know if this could somehow send multiple address to Sensus? :)
I don't have google home. Is it possible to build a simple HTML page with the js script and copy to my phone and load in browser? Hope this is not too much ask. :)
VOC / Connectivity Expert
Do you know if this could somehow send multiple address to Sensus? <img src="http://www.vwvortex.com/Anthony/Smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I don't have google home. Is it possible to build a simple HTML page with the js script and copy to my phone and load in browser? Hope this is not too much ask. <img src="http://www.vwvortex.com/Anthony/Smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
You can send more than one... Out of the box.
tried and only the last one shows up in Sensus nav library received list.
I confirmed @FusionRedSC90 conclusion above with my MY16.
In my multiple sequential tests, the last destination sent (in a series of sending multiple destinations) is retained. In the same setting, I sent Golden Gate Arches (St. Louis, MO) where VOC app confirmed that destination was received; and then I sent Arrowhead Stadium (KCMO) where VOC app confirmed that the destination was also received.
When I went to the car, turned on ignition to Mode 1, only Arrowhead Stadium was received in Library. Golden Gate Archway was not present in the Library.
If I sent the first one and turn on the ignition, the first one is received and retained. If I shut the car off, and send the second one, the second one is also received and retained.
Interestingly and as an aside, if the car's ignition is in Mode 1 (on, not started), the VOC app times out after a couple minutes with a message in red saying "Could not contact your Volvo).
For the short-term, it seems one needs to set up the itinerary while in the car. Hopefully, this limitation and/or sending multiple destinations and having the Volvo retain those multiple destinations (rather than just the last one) can be resolved. Could it be a Volvo USA implementation issue?
Thank you Gary for spending time on this repro and report.
81 - 86 of 86 Posts
