1 - 20 of 42 Posts
Is there a good and proven to work just as well alternative to the Genuine Volvo spark plugs? Trying to save money while doing Stage 0. From what I know, its best to use OEM when it comes to engine stuff (obviously). I just curious to see whats out there. I know some of you tried Denso and NGK.
https://www.ipdusa.com/products/4877/113555-volvo-spark-plug-set-turbo
i'm all about saving money but for something as important as spark plugs i'd just stick with oem
Save money by buying Mahle oil filters in bulk from FCP/IPD/whatever and oil from Wal-Mart, and Bosch coils instead of Volvo... Everything else there's really no point.
Volvo plugs work the best on a stock car.
"Trying to save money.." and R ownership are mutually exclusive.
The plugs aren't that expensive considering how long they are in your car between intervals. Sorry you got a 47k car for 6k and now realize it needs 2k in service. Service it right and it will treat you right.
+1
well the lifetime warranty is worth the extra $10 for oem in this case.
over the bosch coils that is
Do you guys not realize the oem plugs are made by bosch? All this 'oem only' nonsense on this board is maddening sometimes.
Yes, and the Bosch pn is FR7MPP10 but unless you are buying from a dealer you can usually find the Volvo blue box set for just about the same cost as getting 5 bosch.
Oem all the way. Do not cheap out on critical engine components.
Been running Champion with OE spec gap for about 1.5k miles.I do plan to go back to OEM or Bosch this Summer but noticed no difference from the Fomoco(OEM?) labeled plugs I removed. I use 87 octane(R+M) and drive normally,rarely turning the engine over 3.5k. Car went nearly 500 mostly hwy miles on a tank of gas a few weeks ago.IMO it depends on the quality of gas,how you drive,the load the engine is pulling,ambient temp and even the altitude you drive at.
Powered by 5 mad Vikings
87!?!?!? shame on you...
Hell, sometimes I'll put in mid grade when prices are high and I'm on a cross country slog through the flatlands on cruise control. Otherwise I put in the good stuff so I will have full power on tap when its needed.
Discussion Starter · #19 ·
I ordered Bosch plugs from AdvanceAuto, only paid $38 instead of ****ing $65.
i got my oem ones when fcp had a sale, only paid $50 for the set. and lifetime warranty.
so moral of the story is only buy oem plugs when they're on sale, then you get free ones forever
1 - 20 of 42 Posts
