1 - 8 of 8 Posts
Does anyone know if it is documented somewhere the time it takes for a Geartronic to shift when requested by the driver? When I shift manually it seems like a long delay from when I push the stick to when it actually changes,and so I often see the engine rev past where I wanted to shift.<p>Also, when only in sport mode (no manual shifting) it seems very "clunky" when upshifting. I understand it is holding the revs longer and when it finally releases into the next gear there would be some noticeable change, but it is pretty extreme. I don't get the same "clunkiness" when i shift manually, just higher revs.<p>Several people have said in the past that the GT adapts, but I haven't really noticed that.<p>Maybe it is unfair, but I am comparing it to the sport shift mode in my Jatco mated EX35...it is pretty smooth with in sport mode.
Discussion Starter · #2 ·
Re: Geartronic shift speed/clean shifting (inteller)
had Volvo clear what the called "transmission adaptations"....woah this is better.<p>But could I have done that with just removing the battery cable?
Remove batter cables and hold them to each other for a few seconds to reset the ECU...<p>Do this once a week and you'll be happy.
Re: Geartronic shift speed/clean shifting (AthruC)
The clunkiness comes from the increased line pressure commanded by the sport mode. It's supposed to be there (to a certain extent).
Re: (imageomega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>imageomega</b> »</i></TD></TR><TR><TD CLASS="quote">Begs the question:<br>Why does this car "adapt" itself to be so freakin' lame. Is it really all safe tolerance levels? </TD></TR></TABLE><p>'cause you drive lame. <p>Seriously. <p>Drive the car in geartronic / sport for 10 minutes and really attack the road. You should notice after shifting back to GT / non-sport, that the car is shifting higher up in the rev band, will downshift more willingly, etc.
Re: (Needsdecaf)
ok....but there goes the gas mileage numbers I was working so hard on <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>the other problem is I need a road to attack...being set up on a grid system here all of the roads are 1 mile straight sections.
Re: (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">'cause you drive lame. <br></TD></TR></TABLE><p>I suffer from this problem too.
1 - 8 of 8 Posts
