1 - 20 of 25 Posts
So I have an '05 V70R GT, and one minor annoyance is that the light in the S-button on the transmission is dead. The local dealership confirmed that it was just the light, and that everything else works - and quoted me $400 to fix it (because apparently their fix is to replace the whole panel containing the button.)<p>So, 2 questions... <p>Given that I can't tell just by looking that the "S-mode" is on or off, how does this button operate - in particular how does it interact with changes in the 4-C mode? If I switch it on in "sport" and change to "comfort" should I expect it to stay on or off etc?<p>Secondly, has anyone had any experience attempting to just replace the light? My suspicion is that this is a $1 part that has failed, and spending $400 to fix it seems like overkill.<p>Thanks in advance
Re: Geartronic "S-button" questions... (biketrouble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>biketrouble</b> »</i></TD></TR><TR><TD CLASS="quote">So I have an '05 V70R GT, and one minor annoyance is that the light in the S-button on the transmission is dead. The local dealership confirmed that it was just the light, and that everything else works - and quoted me $400 to fix it (because apparently their fix is to replace the whole panel containing the button.)<p>So, 2 questions... <p>Given that I can't tell just by looking that the "S-mode" is on or off, how does this button operate - in particular how does it interact with changes in the 4-C mode? If I switch it on in "sport" and change to "comfort" should I expect it to stay on or off etc?<p>Secondly, has anyone had any experience attempting to just replace the light? My suspicion is that this is a $1 part that has failed, and spending $400 to fix it seems like overkill.<p>Thanks in advance</TD></TR></TABLE><p>The "Sport Mode" button is independent of the 4C, it just changes the engine timings and a few other things to make the car a little more aggressive and responsive on the throttle - if you turn it on and off you can usually hear the exhaust get a little louder/quieter. This sport mode is automatically turned on when "Advanced" is chosen on the 4C.
For $400 I would at least pull it apart and see if I could get to the light source myself. Most likely it's a soldered in LED. If you know how to solder then finding a replacement LED is the easy part.
Re: Geartronic "S-button" questions... (m3nt0s)
Well...<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>m3nt0s</b> »</i></TD></TR><TR><TD CLASS="quote">The "Sport Mode" button is independent of the 4C</TD></TR></TABLE><p>...except...<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>m3nt0s</b> »</i></TD></TR><TR><TD CLASS="quote">This sport mode is automatically turned on when "Advanced" is chosen on the 4C. </TD></TR></TABLE><p>Which is why I ask the question. I know that using "Advanced" turns it on, but if I already had it turned on before going to "Advanced", what happens when I go back to "Sport"?<p>Regarding soldering, yeah, I'm pretty decent at it - but I suspect the trick is getting to the LED.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>biketrouble</b> »</i></TD></TR><TR><TD CLASS="quote">Which is why I ask the question. I know that using "Advanced" turns it on, but if I already had it turned on before going to "Advanced", what happens when I go back to "Sport"?<p>Regarding soldering, yeah, I'm pretty decent at it - but I suspect the trick is getting to the LED.</TD></TR></TABLE><p>Like I said, it operates independent of the 4C, with the exception of Advanced enabling the S Button Sport Performance Mode. The only difference between Sport + Sport and Sport + Advanced is a bumpier ride.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>m3nt0s</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Like I said, it operates independent of the 4C, with the exception of Advanced enabling the S Button Sport Performance Mode. The only difference between Sport + Sport and Sport + Advanced is a bumpier ride.</TD></TR></TABLE><p>Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>biketrouble</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>Which is why I ask the question. I know that using "Advanced" turns it on, but if I already had it turned on before going to "Advanced", what happens when I go back to "Sport"?<p>.</TD></TR></TABLE><p>Nope, it will remain engaged. <p>It changes 3 things:<p>1) advances timing same way that 4C advanced does. <br>2) Changes throttle sensitivity same way that 4C does. <br>3) Changes transmission activity (shift points, logic). <p>When you put it in S, it will remain in S until you shut the car off. You can cycle through every single 4C setting until the pigs come home, but those three things above will be set to "S" until you either turn it back off, or you switch the car off and on, then it defaults to "S off". <p>Easy to tell when it's on, give a measured stab of your foot while in a fixed gear (geartronic active) and see what the car does. Press the button and give your foot the same motion, it should feel like you gained a bunch of power or lost it. If it doesn't , try putting it in advanced and see if there is a difference (aside from ride). It should be noticeable. <p>Also, it's not overly hard to get to the plate under the shifter, but I honestly don't remember the configuration of the circuit board. I am sure that it's one integrated unit. I will look again soon when I switch my shift knob out.
I remember seeing a thread awhile back about a few people who did a complete swap of all lights in the car to change the color. If you can find that thread I bet it will show how to replace this light
Re: Geartronic "S-button" questions... (petew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>petew</b> »</i></TD></TR><TR><TD CLASS="quote">if you can't tell when the "S" button is working, it's not working.</TD></TR></TABLE><p>Yeah, you should know the first time your foot touches the accelerator if the button is on or not, it's glaringly obvious.
In layman's terms for shifting points (something I find the most noticeable about the 'S' setting), the 'S' button keeps the revs higher in most gears so you have instant access to more torque and horsepower without having to wait for the engine to rev up. If you're driving, say at 50mph with the 'S' engaged, the needle will stay a bit above 2k RPM, turn the 'S' off, and it will sink down to barely over 1k RPM if you're cruising. <p>When you step on it, it will also allow the needle to get closer to the redline before switching gears depending on how hard you hit the gas. <p>And it is staggering that they would charge $400 for an LED fix (even if it IS a whole panel--still overkill). I'm sure there are ways around it.
Re: (Jexx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Jexx</b> »</i></TD></TR><TR><TD CLASS="quote">In layman's terms for shifting points (something I find the most noticeable about the 'S' setting), the 'S' button keeps the revs higher in most gears so you have instant access to more torque and horsepower without having to wait for the engine to rev up. If you're driving, say at 50mph with the 'S' engaged, the needle will stay a bit above 2k RPM, turn the 'S' off, and it will sink down to barely over 1k RPM if you're cruising. <p>When you step on it, it will also allow the needle to get closer to the redline before switching gears depending on how hard you hit the gas. <p> </TD></TR></TABLE><p>Here is some good historic (and accurate) information regarding the operation of the GT. <p><A HREF="http://forums.swedespeed.com/zerothread?id=14963" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=14963</A><p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>petew</b> »</i></TD></TR><TR><TD CLASS="quote">if you can't tell when the "S" button is working, it's not working.</TD></TR></TABLE><p>YOU will know that its working... It hauls ass , I think 0-80 in less than 6 sec
Re: (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Here is some good historic (and accurate) information regarding the operation of the GT. <p><A HREF="http://forums.swedespeed.com/zerothread?id=14963" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=14963</A><p></TD></TR></TABLE><p>Cool, I wonder how the 6 speed compares?
Re: Geartronic "S-button" questions... (kitkat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kitkat</b> »</i></TD></TR><TR><TD CLASS="quote"><p>YOU will know that its working... It hauls ass , I think 0-80 in less than 6 sec</TD></TR></TABLE><p>LOLLERS.
after reading this post i actually used the "S" button for the first time the other day. definitely enhanced the driving experience in full automatic. of course, this is a Volvo, which means:<br>More driving pleasure = More maintenance and repair costs<p>i think Volvo should have called it the "$" button. <p>the other day someone asked me why i take the bus to work 2 days a week. i replied, "I own a Volvo, so I try to drive it as little as possible." all i got was a blank stare. clearly not a Volvo owner.
Re: Geartronic "S-button" questions... (vickisue97b)
Ha, I wish my car would stay in S mode.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vickisue97b</b> »</i></TD></TR><TR><TD CLASS="quote">after reading this post i actually used the "S" button for the first time the other day. definitely enhanced the driving experience in full automatic. of course, this is a Volvo, which means:<br>More driving pleasure = More maintenance and repair costs<p>i think Volvo should have called it the "$" button. <p>the other day someone asked me why i take the bus to work 2 days a week. i replied, "I own a Volvo, so I try to drive it as little as possible." all i got was a blank stare. clearly not a Volvo owner.</TD></TR></TABLE><p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
Re: Geartronic "S-button" questions... (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> </TD></TR></TABLE><p>+1<p>and <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
1 - 20 of 25 Posts
