Thanks for the information, Phil and George.
George, yes I did get the keys and car delivered the middle of this past week. I have been spending any spare time I had this week going over her and looking for the first potential problem I should tackle. Mostly I just stare at her, though. With Isaac coming and whipping us with bands I haven't taken her out of the garage but for 15 minutes to wash the cross country road grime of her. She's beautifully straight and appears to be pretty well cared for. Not perfect, by any means, but exactly what I wanted.
I gues this is as good a place as any so I'll tell you what I've found so far that I need/want to address over the next few months. I haven't put her in the air yet so this list might get longer...
-leaking coolant slowly from one place
-leaking oil slowly from two places
-DS front jack point partially rusted through where it meets the frame rail with rail involved slightly
-PS front jack point partially rusted through but doesn't involve frame rail
-about a dozen small dents/dings and a few areas of hand-applied paint touch-ups
-ignition key lock is broken around the outer ring; also engine will not stop if headlights are on, even if you take the key out of the ignition!
-PS amber side marker lens is cracked
-paint is original color, but I suspect not original paint; paint is pretty unevenly worn on the hood and pontoons and finely spidered around the A-pillars
-PS headlamp is cracked and chrome bezel is loose
-window scrapers are both loose and a little dry
-Engine compartment rubber gasket nearly dust
-under dash A/C blows warm
-aftermarket cruise control needs a sturdier bracket or I will just D/C it entirely, not decided yet
-lots of spliced wires in the engine compartment, not sure if this means there was a fire or if up there were just a lot of electrical issues that needed to be addressed; has hot spark ignition that looks fine, tho
All that being said it's very easy to extol her virtues. Straight body, everything works, lightly modded ride height was done correctly, lots of new parts that I have all receipts and records for, etc. I will post updates if anyone is interested.
