So, my issues with the IPD R boost gauge have kind of pushed this to the front of my mind, and I can't seem to find a good central thread for this kind of info, especially for the P2R's.
Forgive me for my inquisitive mind, but there are tons of gauges available, and I'm curious how "vital" each category is to keep an eye on, if anyone has installed one and likes it, and how they installed it.
This is a potentially massive and informative thread, so I hope lots of folks will contribute! I'm interested in what adapters/senders various gauges require to install, and what the best routes for wires/tubing would be for them.
The boost gauge category is chock full if you search, so I'm skipping that
Water temp gauge: The R already has one, but it's a unnumbered gauge. Should I need one? I'm guessing you have to get a radiator line adapter with the sensor mount for this to work right.
EGT [Exhaust gas temp]: Hot exhaust gasses are a good thing when it comes to scavenging, but they can also be a symptom of running too lean and...boom! Would this be a good one to do when the shop puts on a custom exhaust? How high on the priority list should it be?
AFR [Air fuel ratio]: This one has been covered a fair amount as well. How do narrow band and wide band AFR's compare on our caRs? Is a wideband worth the extra money? This will also help diagnose if you are running lean/rich.
Oil pressure: I know our caRs have a warning light for this, and if you get that light, you're basically $%^&ed. More importantly, how does one install the oil pressure gauge, since our filters don't seem like they'd accept the sandwich adapters some aftermarket companies offer.
Oil temp: Should we worry about this one? As far as install, same as oil pressure above. Where/how do you install it?
Fuel pressure gauge: This definitely seems important if you're getting tuned for really high output, but would it really be worth it if you're staying stock or lightly tuned/modded? Also, where/how does this install on our caRs?
Transmission temp gauge: this really only applies to us GT owners, and I'm guessing it's somewhat similar to the oil temp gauge. Anyone put one in or have suggestions on this one?
Volt gauge: I'm running the factory sound system and don't have NAV, so I'm not too worried about power consumption. However, I believe these are handy if you want an underdrive pulley, have lots of sound system extras, or just want to be cool. The AFR I'm looking at also monitors the voltage, so I'll have that covered, but someone might want a designated Volt gauge. Easy install??
Air intake temp gauge: There are several locations to take this. The most rational place is the intercooler out endtank area to see how cool you're getting the intake charge. I'm looking at a gauge that measures both the in temp and out temp on the intercooler, just cause I'm that guy. It's made by Prosport, if anyone wants one. Anyways, install method??
Thanks in advance for your contributions!!
