1 - 6 of 6 Posts
Hey guys, quick question to simply gather ideas as to where this smell may be coming from?
After some time doing WOT runs up to high speeds I get a gasoline smell coming into the cabin. It's not a strong smell, but enough to realize there's gasoline fuming in. After watching around on YouTube, I figured it could be a bad o-ring on one of my injectors. Is this plausible? Where else could there be a leak? I appreciate the help beforehand.
PS: I've replaced my fuel filter less than 30K miles ago. I've also replaced my gas cap around that time too.
Could be the evap canister - if you've every really overfilled the tank, that could be something that has to be replaced.
Is there a fuel smell any other time than WOT? Evap/charcoal canister is normally open to air. If it were contaminated you'd smell it outside the car or all the time. Injector o ring is possible. But if it's that strong it might be an intake manifold gasket.
Generic answer: loose clamps or aged fuel lines somewhere, particularly in the cold. You end up with a mild fuel leak, and WOT you're pushing a lot of fuel, which exacerbates it.
1 - 6 of 6 Posts
