So i noticed that my R is smelling gas in the oil, when i smell the dipstick it smells and also in oil cap.
Where should i start with this ?
The oil still seems at normal viscosity, it's not thinned.
Should i try to light up my dipstick and see if it catches fire instantly, this way i can have an idea of how much contamination ?
My oil has been changed recently.
Thanks in advance.
Bad rings, leaky injector/low fuel pressure.
Too many short drives won't help.
When you figure it out, change the oil again.
for me it was lots of short trips which resulted in a PCV system replacement at 45k.
Also make sure your ignition system is up to snuff, incomplete combustion and misfires will also pass unburned mix and fuel build up on the cylinder walls past the rings.
