1 - 8 of 8 Posts
Is there away to decrease the resistance of the gas pedal. Seems hard to give the car gas gradually. Would like to decrease the amount of force needed to accelerate.
Our cars have weird pedal sensitivity. Seems like the first 10% depression does nothing and then you hit the turbo, scares anyone I let drive my car (in parking lots of course).
I can't imagine it would be too hard to adjust the pressure that is needed, as the pedal is electronic so it's independently operated from the actual throttle. But I don't think you'll be able to tweak the sensitivity any, unless you do mods that change the throttle response.
I think "drive by wire" is the biggest issue. I know on newer Isuzu Rodeos that went to that they have a delay in throttle response that I dont with a cable operated throttle.
I know that it is drive by wire, but the resistance on the gas pedal is too tight resulting in a quicker, more abrupt acceleration.
A tune can change and does change that but that's about it.
There is a torsion-type return spring that gives the pedal the resistance you refer to. But there isn't anything you can do except to change it to a softer one at your own risk.
It's a drive by wire system so the throttle response could be altered with a tune.
I wonder what the accelerator unit goes for. Might buy a used one if it isn't too expensive to tinker with.
New ones are $105-120 on rock auto. So used ones should be about half that.
1 - 8 of 8 Posts
