1 - 20 of 32 Posts
· Registered
does anyone here know how the gas door is programmed? I notice it is locked at certain times and does not lock at other times. is it set to lock on a timer once you lock and leave your car? I'm concerned hearing people have had their gas sucked out of their tanks due to the high gas prices.
· Registered
Re: Gas door (blackTT55)
Quote, originally posted by blackTT55 »
Once you lock the doors - the fuel door will lock ten minutes (or so) later. This allows you time to fuel up after locking the doors for safety.
John Sharisky
· Registered
Re: Gas door (Parts @ Boston Volvo)
Quote, originally posted by Parts @ Boston Volvo »
John Sharisky
I don't understand the logic behind that but thanks for the explanation.
· Registered
If your stuck filling the tank on one side of the car, you have the option of locking [the far side] doors in order to protect passengers or cargo.
John
· Registered
Huh? Maybe this wasn't the case on an '01, but my '04 fuel door locks only when I get above 10 mph. Per the manual, nothing else should lead to its locking.
· Registered
Re: Gas door (VTT5)
Quote, originally posted by VTT5 »
This does not make sense, so you mean anyone can open up your gas door and and put sugar or whatever the hell they want to in your gas tank while the car is parked and destroy your engine?
· Registered
Re: Gas door (VTT5)
...nothing else should lead to its locking...
We were discussing the locking of the fuel door after the doors are locked when the car is stopped (I thought). The fuel door delay as I mentioned is programmed into your Volvo at the factory. This, along with a lot of other parameters, can be changed as you see fit via software downloads at your favorite Volvo retailer.
John Sharisky
· Registered
2001 was the ONLY year where the fuel door did not lock
· Registered
Re: Gas door (JRL)
You're mistaken. The gas door does lock because I've seen it locked on my car plus the manaul says that it does. The question isn't wether the gas door locks or not, it's if it is on come kind of timer and I think John Sharisky's reply is right on the money. I think it's set on a 10 min. delay after you locked the car but I will test to confirm.
· Registered
Re: Gas door (wrodri54)
The gas cap can be programmed to lock immediately, or after about 10 minutes. There is an additional function to allow all the locks to be locked once the car is moving over 7 mph.
See this site for some of the options, but not all:
http://acctest.semcon.se/en-GB...3.htm
Check out some recent posts, about the gas cap locking. This has caused much confusion, because it seems to be different on every car, but probably was done by default at the dealer, and the original owner didn't know it could be programmed differently.
· Registered
Re: Gas door (afterimage)
Quote, originally posted by afterimage »
Mine locks as well, it is an '01
Yep, all models lock, but 2002 and newer models have a dash button to unlock the fuel door (it locks automatically once the car reaches a few MPH). In 2001 ONLY, the fuel door unlocks/locks with the doors (but with a delay as some have indicated) and there is no dash button.
· Registered
Re: Gas door (Warpedcow)
What confusion...my S80's fuel door never seems to lock anymore. Why can't they just leave it manual, or have a key-hole like Toyota does? I remember hearing the clunk from the back when it locked as I drove away, but now it doens't. Oh well, not a big loss. Sugar doesn't do much anyway. Urban myth.
· Registered
Discussion Starter · #18 ·
Re: Gas door (Majisto)
Same deal with the trunk release.. why the hell didn't they just put a trunk release button in the car. I'm have to use the remote to open the trunk at times. Weird...
http://********************/smile/emthdown.gif
· Registered
I think because of how everything ties into the security system. That's why using the key in the trunk makes the car go ballistic, which is very silly, but whatever. Most people don't keep these cars long enough to have to deal with higher-mileage car issues.
1 - 20 of 32 Posts
