1 - 1 of 1 Posts
A non-working garage door even after pressing a wall or remote switch often point towards a disrupted power source. Check for any unplugged motor, a burned out or tripped fuse, circuit breaker, faulty outlet powering the opener circuit, or repeated tripping of the breaker or outlet points indicates a malfunctioning opener. When other electrical circuits or lights in the garage do not work as well, you should reset breaker and replace any burned-out fuse. Further, if the mounted keypad or wireless control is not opening the door move closer to the door as it's the antenna's range may be low and receiving signals could be a challenge. For any of these problems, immediately call garage door repairs in the Western Suburbs of Melbourne
1 - 1 of 1 Posts
