just installed a dashcam in my polestar, but the cover of the fusebox wont close with the add-a-fuse. Is there any way around this, or anyone with a good solution?
Discussion Starter · #2 ·
also im using the glovebox fuses for a dashcam with parking mode, so need an switched and a constant on fuse. its been a pain since i think i get a good setup then when i lock the car the unit boots back up. which fuses are you guys using?
The heated seats don't cause you trouble? Other cars I've had issues with fuses like that not knowing when they are powered and when they aren't. I ordered a few extra fuse box covers and may drill some holes to give it some space when I finalize the fuse locations.
