Anybody know a good fuse to tap on the panel near the drivers door for this? Either already in use or blank? Preferably a circuit that is only energized when the key is in or the engine is on!
Check the drivers foot well panel. There's circuits that are only live with the key in position two. Forgot which one I used but it would be easy to figure out with a test light or meter.
Tried the blank ones for RTI and telephone. But they are live without the key in. Gonna have to tap ones that in use I guess.
For an 04 you can use the 12V Accessory plug socket fuse. If you need to make your own fuse tab, you can Dremel one side of the fuse tab to expose the metal, solder a wire to it and BOOM, switched ignition power! Should be fuse spot number 13 but I would recommend checking with a multimeter.
