1 - 2 of 2 Posts
Discussion Starter #1
hi all i have had my 460si for about two weeks now first volvo and i'm lovin it but it makes a funny noise the only way i can describe it is it sounds like two metal objects rubbing against each other and it only happens on gear change (its a manual box) its had a new clutch in the past 9000 miles so i was just wondering if its a normal noise or something more sinister???<br>any ideas anyone???<br>Andy <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Hello
You can start by checking the oil from the gearbox. Usually, the oil flows when the gearbox is detached from the engine.
Also the bearing form the clutch might be fitted wrong. Too tight or something...
You should also check the gearbox mountings and the heat shield.
1 - 2 of 2 Posts
