1 - 13 of 13 Posts
My R is an 05 VR and I'm getting two part numbers for the PEM off VIDA.
30742823 is for chassis #'s 541131 and under.
30769225 is for chassis #'s 541132 and over.
My chassis is 520118 so I need 30742823, but I'm having a bit more trouble finding this one over the other. I got a little click happy and ordered the newer version, 30769225.
What is the difference between the two? Some sources say they are the same.
If I had an SR the chassis break occurs at 509561 which points me to the newer version.
Give me your vin number I'm at work now and I can pull out the right part number for you just dm me
PM sent! Thanks.
It looks like the right P/N is 30742823 but I want to know what the difference is between this and 30769225.
2005 V70R Passion Red : IPD Springs : IPD Track Spec Sways : IPD Rear Camber Kit : TWM Short Shifter : MOMO Shift Knob : IPD Downpipe : Snabb Intake Kit : Viva CBV : Resonator Delete : PU Rear Toe Link Bushing : PU Front LCA Bushing : IPD HD Coilpacks : AVIC-x950bh : Aftermarket Stealth Subwoofer : Viva Single Mass Fly / OE Clutch : Motor Replaced : Custom Digital Boost Gauge : RICA Stage II : Snabb FMIC : Niche Targa 19x9.5 / 19x8.5 Staggered :
PM sent! Thanks.
It's 30742823 you can't use the other part number on your car both parts might look the Same but the electrical part inside and the network are different... Hope I answered your question
I have a used 30742823. Send me a PM
PM sent!
I bought a used one from a member for 45$ It came out of a car that had it mounted on the inside from the factory. I took my old one apart and it looked good but for a few $$ it was worth it. good luck!
It looks like one of the differences between the two part numbers is a plastic tank vs metal tank. Why would this be important for a PEM? Still trying to figure this out. I'm thinking the later version is improved in some way?
I have had 30769225 installed now for a few weeks now and I can confirm that there is no functional difference between the two p/n's for these PEM's. The internal components match each other.
Hope this will help anybody out there looking at PEM's. 30769225 is easier to find and cheaper.
Old thread but...
I just want to echo what Sachio said above.
- I have a PEM I removed from a junk yard (2004 V70 2.5T with metal tank), PN 30769225.
- My 2005 XC90 2.5T with 120K miles has the PN 30742823.
I removed PN 30742823 and installed PN 30769225: it worked perfectly for weeks, zero issues whatsoever!
- I am not an engineer but to me, these 2 parts are interchangeable.
Hope this helps someone out there trying to use these 2 parts...
2006 v70r 138k, Sold : 2004 s60r, 1999 s70T5
Hello; I dont have VIDA/DICE but I do have a car I cant drive. It runs good for about 30 minutes then, I cannot take it above 3300 rpms, when I limp home I plug in my ODB II and I get P0087 AND P0089. The fuel pump was changed by the previous owner and I have the PEM out and in my hand, it is part 30769225. I dont want to just replace parts so how do I test WTF is going on ?
1 - 13 of 13 Posts
