1 - 2 of 2 Posts
Does anybody know if the Fuel management system sends voltage to the pump only during start up and when the motor is running? I'm having problems with my 98 V70 T-5 and when I hook a voltmeter to the fuel pump power connector, I get no voltage at on and then 10.91 when I activate the starter. I think I have a bad check valve because its hard to start sometimes and I have pitiful resting pressure at the rail, but I would hate to buy a new pump if the relay may be at fault. Thanks for any input.
Could be your ignition switch. The pump should start working with key in position II if I recall correctly. Electrical component of the switch is fairly cheap from fcpgroton.com.
1 - 2 of 2 Posts
