1 - 20 of 22 Posts
hey guys
Lucky me has come across another issue
lately I have experienced low gas mileage and slow boost build/slower acceleration. Incorporated with that I have been having misfires on all cylinders randomly under random driving condtions. The misfires dont even throw a CEL
anyways, used VIDA and came up with this
ECM-2900 (fuel pressure-fault)
ECM-440B fuel level-signal missing
Volvo Of Worcester up here denied me service.....
So Im trying to see what the heck is going on..
Side note fuel pressure goes up under deacceleration.
And under acceleration pressure goes down a bit
Thanks guys
Denied you service?!?!?! what was their reasoning? that's just retarded.
Could be the FPS. Cheapest of the options too fix yourself (others being fuel pump or fuel PEM)
because I am "modified"
ya im looking to get a proper check over by someone because I cannot be spending gobs of money on random things :)
gobs of money must be more then $75 then since that's how much the FPS cost ;)
Is your car under warranty?
No warranty...IM almost tempted to swap fps with my Moms R lol. but no access to that and she would have a BIRD lol. What doesnt make sense is that fact that the car reads the correct fuel pressure when data loggin with vida....:(
Weird, I can see being denied for warranty work but refusing just cause your modified is ridiculous. IDK then my FPR psi readings were crazy when mine failed like shooting up to 130-150 psi in the reader whenever I made a turn :D I replaced the part and all is well. Good luck.
And the pressure seems to drop under acceleration lol
When I decelerate it jumps up
Vio, the voice of reason.
PEM......mine went bad recently and my gas mileage took a def hit as well as throwing the code for the FPS(although the PEM will throw this code as well when they start to die. My FPS was new-ish)
Discussion Starter · #19 ·
Cost of a Pem ?
I paid like $247? I do get a discount through my parts guy. Close to Tasca's though.
1 - 20 of 22 Posts
