Fuel pressure drop on right turns. <solved>
04 S60R 148k miles. Fuel filter was changed at 114k and spark plugs at 100K.
I had a rough idle and hunting issue a few months ago that I was trying to diagnose.
With the help of N23, I cleaned the throttle body and the maf with no change.
Disconnecting the MAF made no difference. So I discounted that as the problem.
I narrowed it down to the PCV system, which I have replaced. No more hunting, however it still idles rough.
I also have had a random misfire & cyl 1&3 code that reoccurs every 6 months. But after this issue it stays on.
To add insult to injury, the fuel pump started leaking.
I finally take it down to the dealership to get it replaced under recall.
Shortly after, the fuel pressure keeps dropping down to 30 psi on right turns, but not on left. I'm using the torque app and an OBD2 dongle to monitor this.
Then it started stumbling when passing. So I replaced the fuel pressure sensor and all the coils.
Pressure still drops when making right turns and hesitating/stumbling when this occurs. I also had the fuel pressure start dropping on one occasion at idle and eventually stalling out when it dropped below 30 psi.
I'm thinking maybe the PEM, but the connections looked clean, no corrosion and no rattling.
On a whim I flipped it on it's bracket in case something was loose, but pressure still drops on right turns and not left.
I take it back to the dealer with the code P0089 Suction control valve stuck.
They said the put a mechanical fuel pressure gauge on saw NO DROP IN FUEL PRESSURE. They cleared the code saying it was probably due to the fuel pressure sensor I replaced. They said Vida showed no codes regarding the fuel pump.
They refuse to acknowledge that the new fuel pump or the installation maybe faulty and never pulled the fuel pump to check.
They said it stalled several times at idle and attributed it to the MAF because it ran better when they swapped the MAF and said there was a leak at the PCV/intake manifold banjo bolt.
After a $140 diagnostic fee, they quoted $200 to replace a washer and $750 for the MAF, and 300 for a leakdown test(to diagnose the misfire).
It seems like my rough idle issue is found, so I ordered a MAF myself. When driving today, the code P0089 Suction control valve stuck came back.
But I'm still baffled by the fuel pressure drop on right turns. It has to be something mechanical in the fuel system. If the fuel pressure is not physically dropping, something is telling the ECU that it's dropping, because that's what I'm monitoring on my torque app.
I also broke down and ordered a VIDA/Dice unit which I will receive next week.
I should add that the car never went into limp mode.
