2011 C70. Fuel level consistently wrong. Assuming the fuel level sending unit is integrated with the fuel pump?
If so, does the tank need to be dropped to replace fuel pump unit or is this accessible by removing the lower rear seat and lifting carpet?
Any advice is greatly appreciated. Thanks!
Tank has to be removed...
On the s40's I have removed pump by partially dropping tank. Not that bad.
I think problem is possibly in CEM though. Under dash on passenger side take off each harness and inspect. I'm betting you have some corrosion. Clean them up good and see if your gauge starts behaving.
