1 - 20 of 20 Posts
After replacing O-rings, was installing rail and the little brown disc broke off, some of it went into the intake manifold.
Think it'd be safe to drive until I get new injector? With new o-rings, I don't think any fuel would leak. Not sure what the brown disc is for.
I would not drive it if its in the intake manifold. It will get sucked into your motor and maybe even cause it to lock up. Not a expert but I would not risk my motor. Have you tried to suck it out with a vacume just empty it first so you know if you got it out.
Get 5 seal kits. The piece missing slips on injector as an o ring seal retainer.
Bosch type III injector seal sets sare available several places including Ebay.
Probably available at a local chain auto store.
How big are the lost pieces?
I've ordered injector rebuild kits from these guys before. Not for my R, but they should have them too. Their kits include upper and lower o-rings and the pintle cap which you broke.
http://bostechfuel.com/
Bought and shipped; should be here Thursday. Called everywhere local, none carried or knew anyone who carried seal sets. Jacksonville stinks like that. I miss living near Charlotte, NC where you are surrounded by car guys.
The lost pieces are 75% of the retainer ring. Being it was that brittle, I'm thinking it should shatter under any pressure at all. Unfortunately it has slipped past the hole into the valve area just past the manifold. The only way to get it is remove the manifold. Grrr.
I would not want to have to endure that amount of pucker factor when first starting after replacement parts arrive, good luck.
On type III it is not the pintle cap like it is on round earlier style with exposed pintle. Type III is the disc face type with the plastic flange washer. You definitely do not want a pintle cap on a type III.
If the washer is brittle then it will crush and be gone out the exhaust and will burn down in the catalyst.
Being that the bits that fell are of a brittle plastic, they won't pose an issue for the mechanical parts. I don't see any issue with burning them through. Most likely, they'll get covered in gas, ignite, melt, and smolder into dust. Some bits may even just get sucked straight out the exhaust. I'd only be concerned if they were of a material with a high melting point and abrasive.
I'm no expert but I think there are various styles but they are all called pintle caps. I've never seen the disc style called anything else.
I'll be running a section of vacuum tubing down the injector hole and vacuuming out. If it picks it up, great.
BTW, Turned out the issue wasn't the pipe coupler after all, as you see it isn't broken. The o-ring behind it had just gotten old enough to start leaking. So dealer wanted $650 to replace $0.13 part that is quickly accessible on top of engine, heh. Thinking I should retire as programmer and go into a life of crime, a.k.a. auto service.
Did you get this resolved? I have the exact same issue with one of the injectors on my 06 XC70. Tried the dealer & a couple chain parts places, can't find the plastic disk without replacing the whole injector. If you found a source I'd love to hear it where you ordered from.
Lol love this- totally true
One of those broke off when I was doing my PCV, I just didn't put a new one on. Haven't had any issues. I also got it out of my intake before I reinstalled...
Did u ever get it out? or just start her up? I know someone who had a problem like this and just ran it and 2 months later the motor locked up is why I'm asking.
There's no way a small piece of plastic would lock up a motor. It would melt, and disintegrate before it could cause any engine damage. I mentioned that I got it out, but I also had the intake manifold off so it was easy.
It was not a R and not sure if it was plastic his motor locked up piston dug into wall or something. I don't see the guy anymore or I would ask him.
If it were metal it's a different story, but there's no plastic on this earth that can withstand 2K degrees F. Just sayin'
Discussion Starter · #20 ·
First tried to vacuum it out; didn't find it, so I just started it up and there were no problems, so far. Pretty sure if they were brittle enough to break under insertion pressure, the remains probably got shattered, burned, and sent out the exhaust.
1 - 20 of 20 Posts
