I started doing some service work on my 2001 C70 today - timing belt, water pump, thermostat, plugs, evaporator, heater core, A/C dryer, oil change & a fuel filter.
I figured I would start with the fuel filter, I crawled under the car and my fuel lines still had the masking tape on them indicating the filter was original.
I removed the masking tape and pushed and pulled on the lines but they won't come loss. I googled Volvo fuel filter removal and a forum post said to use a 17MM open-end wrench to push the fuel line connecters back and release the fuel filter. I hadn't thought about using a wrench but it made it very easy to remove the fuel filter connectors,
Thought that tip might help somebody, I also put some oil on the fuel filter nipples so they would slid in more easily.
Now for my slight problem
I started removing parts of the dash so that I could get to the evaporator & heater core, when I removed the lower dash panel on the drivers side I noticed their were non-factory screws holding it in place. When I removed the panel I noticed that the upper taps that the panel fits into are broken off completely, so the panel won't clip / hang in place.
Has anybody seen this problem before, it looks like the only way to really fix the problem would be to purchase a new dash board and I don't want to do that, is their any repair kit for this problem or is it very uncommon?
Thanks
VERY common. Plus the screw directly under the steering column is usually toast
I and many others just run a screw thru the removable lower pad into the dashboard
I used an extra Volvo self tapping torx head screw. So it looks factory
Someone here or on VS used magnets
Try googling volvo x70 sagging dash panel
