1 - 15 of 15 Posts
fuel filler cap open loose
checked my cap and the seal looks brand new and it closes like it should, what could it be
thanks !
EVAP system has found a big leak and is assuming its the cap most likely. Bad news is that if the gas cap is good you have a leak somewhere else in the fuel system. The R is known to have some issue with the seals on the access ports to the fuel tank so my advice would be to check them out. Have you noticed a gas smell around your car, especially right after its been filled up?
I see, I didn't notice a really strong gas smell around the car. Where exactly do I check for those seals on the access ports, where are they located.
Also want to mention that the message comes on a off from time to time, its not the first time I see it and it popped again a week later today.
Is it dangerous, I mean if I use lighters in my car and etc.
ty stealthy
ty stealthy
Had the same problem. Swapped a new gas cap in, problem solved. :)
How could the seal / Oring be like new on the cap ? It's ten years old . It may have cracks , I personally would put a new one on first . This has happened even if the cap was not turned tight to 3 clicks on my o2 v70 , replaced Oring no more problem
Start with the basics, get a NEW OEM Gas cap. Had this issues with mine this summer, gas cap solved the issue.
And BTW my gas cap looked brand new too...
Funny how I read this and I got the same message for a few minutes then it went away. Not I just have a CEL I have to get read and cleared but I'm pretty sure it's fuel cap related. It also just started happening after my last fill up where I dropped the cap....
The message did not come back on for a few days now, pretty confusing, going to let as is until it starts to pop more often.
I had the same issue on a 2.5t S60. Intermittent just like you describe. It would come on after long drives up the northeast, so maybe the change in temperature would cause pressure changes? Unsure. Either way the O-ring replacement worked and the code never came back.
Just to throw my two cents in, I found a similar issue with my XC70, but even after replacing the gas cap it only made a difference for a few months. It turns out that there is a rubber hose that connects two pieces of hard plastic line for the evap system together. The hose was leaking and then completely popped off. I believe this is outside on the passenger side floorboard just behind the subframe. I put mine back together and zip tied the connection. Problem solved... for me.
This post is dead, get a gas cap!!!
It's arriving Thursday from FCP. Cleared the code. Message pops up for a few minutes then goes away. Turn the car off then back on and I have a CEL. Really hope it's the cap!
1 - 15 of 15 Posts
