This has happened to us twice now. We go to put gas and the fuel door wont open. No matter how many times or the duration of time that I press on the fuel door, it doesn't pop open. It will randomly open while driving after it being stuck for sometime. Anyone else having this issue?
When I picked mine up from the dealer the fuel door was stuck. It was the little rubber "boot" on the door side of the fuel door. That boot got pinched somehow in the wrong spot. We were able to pry it open and they just switched the boot from another car on the lot. Worked perfectly since then.
You might make sure that boot is securely on the step is sits on.
Yes - had this too. Went to fill up with fuel, flap wouldn't open come what may. The car was definitely unlocked. Sat with the dealership for 4 days. Pin mechanism would not release. They Replaced entire cassette (that's what they called it).
